I did turn it off. I went back and reloaded it again and made sure I turned it off and it still throws p242d and the absolute manifold pressure code with the lightning bolt. Anymore ideas?Directions?? Turn off EGR/DPF??
are you running sims or factory exhaust probes?
Factory probes. Another question is running with the even numbers alawys a code as soon as I start the engine.are you running sims or factory exhaust probes?
Yes that is the code. I like running the even numbers while pulling big loads.Another member here has had that same problem while running even numbers. It is the P0106 code?
Why? The added timing keeps the EGT's cooler and increases MPG. I would run the odd and I don't see any use for the even unless you are stacking.Yes that is the code. I like running the even numbers while pulling big loads.
I think it is the different sound of the motor from the timing thats weird to me. I never thought about the egts being cooler from the timing. Thanks for the advice.Why? The added timing keeps the EGT's cooler and increases MPG. I would run the odd and I don't see any use for the even unless you are stacking.
Thats the way mine is, 30 to 40 miles. If I am pulling a load it comes alittle sooner. Thanks and keep Me posted....crackercwboy, I have had the exact same symptons on my truck as you have. I am using a beta version of the smarty now that is supposed to get rid of the p0106 code which it does but my truck still gets the symptoms like before. I ordered some sims and replaced the stock egt sensors that where zip tied up and ran the truck a little bit tonight and so far so good but only time will tell. mine would act up but I had to drive it about 40 miles or more to get it to act up which I didnt have time to do tonight. So I will post up any info I find out.
