hi my recently purchased truck surged at all engine rpms (just a small surge like a gas engine missing a little) when i reset the smarty from 3 to stock it improved it a lot. has anyone else had this happen ? i'd like to use the smarty if needed but like smooth power. thanks truck shows no codes.
its your injectors, when you go to reflash change your duration up 1 click. it solved my issues.
as for the pedal surge that is normal, your pedal will be more responsive.
Reactions: sinbad
Hmm if you have messed with the revo settings at all im thinking you maybe turned up duration or timing a lil to far. Or you might just not be used to how the smarty feels. Did you notice an increase in power or just surging?
