1 - 14 of 14 Posts
Found a used smarty so3 for sale $450 for my 99.
You guys happy with the smarty tunners?
If i stack with power puck will it work well?
Will it wake up my truck more than the power puck i have now?
Any info would be great, thanks.
5-speed, i have a power puck and thats it, im looking for some rv275's. Valair clutch.
Im not worried about the "weakest link theory" i just was looking for answers from members who have used a smarty so3. Thanks
That was what i was wanting to know, you can set the smarty for use with a timing box, i didnt know if i should use the smarty for timing? I would assume to use the smarty and no power puck but ive heard of others use a separate timing box. Thanks
· Rescue Tower
1. You can run Smarty with anything
2. I don't think Smarty is worth it.
It helps the bottom end but that's it, and usually lowers over all top end even when stacked with another box. I recommend spending the money on injectors instead.
Without going smarty what box would yall recommend with out tapping pump wire for best bang for buck?
I think the smarty and comp box are the two best combos around... Both are very good mods!
· Rescue Tower
They are all about the same. If you have the power puck already, keep it. If not look for a used one, or Edge EZ. I would not buy one new.
I ran a puck smarty stack, wasn't a bad combo, use puck the puck for timing and smarty for fuel and its a lot cleaner. Added bonus you get a code reader too
450 dollar code reader that doesn't work on anything else..
1 - 14 of 14 Posts
