Does running either of these require the need for a lift pump upgrade? On stock mine stays at 15, and the lowest I have gotten it is at 5 with the puck on 90.
i would definatley do a lift pump upgrade the smarty will pull you down way low if saw 5 with the puck, the smarty capable of 230hp.
a lift pump would be a very good idea. i actually have a fass sitting at the house but my stocker is still holding up good, even with tnt on sw9. so until my stoker gives up i'm gonna keep the fass on the shelf
Banned
Depends on how high you turn the Smarty up. You can get by with the stocker but you would be wise you go with an aftermarket unit that will filter to 2 microns or less.
i would definitely do a lift pump, bosch (who made the vp-44) recommends no less than 10psi at WOT. any less and your running the risk of destroying your vp44 i put a glacier LP on mine, i dont have a chip YET:lol3: but mine doesnt go below 14 psi at WOT
Banned
CP3 is good to 0 psi...it's just better to have pressure.
:agree2: was gonna say the same thing...
