I wanted to know if either or has its advantages?
Do both of them come with its own case and all?
Thanks...
Thanks...
It will not work for the 6.7, the s06 will work for any year CR 5.9, you can only get the s06 cause it replaced the s04.So the software updates are the same but the only advantage is the S-06 will also do the 06-08?
If that is the case, I want the S-06 version so I will be ready for anything from 03 and up.....
Now the S-04 will have all the bells and whistles as the S-06?It will not work for the 6.7, the s06 will work for any year CR 5.9, you can only get the s06 cause it replaced the s04.
Thanks Farmboy!! I cant wait to try it out. I was just concerned about the difference in versions but I see that the S-04 is no longer in production so I am sure that a S-06 will show up on Tuesday!It's on the way. :thumbsup
