1 - 4 of 4 Posts
i was wondering about the smarty revo tunes for the rail pressure. is mild too high for my stock injectors? i like the throttle responce with it on #2 but im scared of cracking an injector we all know how sensitive the cummins cr injectors are. please if you could let me know about this
i'm not running basic revo, but i'm running revo tnt. with rp3 i was hovering around 20,000 with spikes up to 25,000. according to don m cruising at 20,000psi is unhealthy for the injectors. i then uploaded rp2 and now i cruise right around 15,000 and have a hard time getting over 21,000psi at WOT. I hope this gives you an idea of where you're at.
what pressures will you harm the injectors (stock injectors)??
"cruising is best if under 17,000psi. idle is best 5500-7000psi. wide open if used sparingly can go 26-27,000 and never have a problem. Dont cruise the freeway at 20K plus ever". this is a quote from don m, the Man when it comes to injectors.
1 - 4 of 4 Posts
