1 - 13 of 13 Posts
I have yet to put the smarty jr in. I'm waiting to finish installing my gauges that way I can monitor the pressures and temperatures the truck runs at stock. Anyways what setting on the Smarty Jr will I see the largest fuel mileage increase? My truck is stock except for the mods shown in my signature. Can I run this at level 3 with stock injectors and tranny? Thanks!
I've got my best milage on the 100 horse setting sw3. If I can manage to keep my foot off the skinny pedal on the right.
So I should be safe to run it on the 70-100 hp setting with a basically stock truck? I won't be towing anything greater than 10,000-12,000 lbs, and that is only every now and then.
Yes, if you drive responsibly you should have no issues. Keep in mind if you beat on a stock truck the trans won't hold up very well..... so if driven responsibly, you will be all smiles
Discussion Starter · #10 ·
What would you consider "beating" a truck? I guess this is different for each individual
i am already having to upgrade the tranny. 60k miles total on the truck with about 3000 with the smarty jr. most all the time the jr. is set on 70hp. i ran it for 2 days with it on the 100hp and it was too much for the tranny right away. this is with zero boosted launches, zero smoking of the tires, and no just sitting there trying to kill my truck. i do however use it to drive a little rough from time to time. my main problem seems to be the slipping of the torque converter. if i am running along already moving and then romp on it, the TQ will slip and then eventually catch. as far as an increase in mileage. i haven't lost any MPG, but because of the way i drive, i haven't gained any either. after all my tranny stuff comes in from JBARKER i will report how it turned out. i should be able to run it all the way up without problems. we'll see. if so, i'll be ditching the jr. and going with a sr.:woot::$:
Discussion Starter · #13 ·
Ok that's what I thought. I mean I accelerate hard all the time but can't afford to be burning up tires.
1 - 13 of 13 Posts
