A few different quotes:
We seem to have two different notions of how the STOCK software is returned to our ECMs ... can you give us the definitive answer as to how it works please Bob.
tia
The Smarty JR doesn't have any flashes in it.........it saves what is currently on your truck and then you can put it back to whatever is saved as "stock"
smarty doesnt save what is programed on the ECM, however when you return back to stock it will use the latest flash that is current on its memory. this is why it makes sence to keep it updated since Marco and Bob make sure to encorporate the latest factory flashes into the programmings.
Well, I sure hope this isn't true ... there will be literally endless combinations of so-called "STOCK" software on all the trucks out there from 2003 to 2007. This doesn't make any sense at all; that Mads would wipe out each of our individual ECMs software and then install it's own generic version. Man I hope this is not true.
I just had some new flashes done at the dealer so this would mean they are gone now. I hope not.
There have never been any downloadable updates for Smarty Jr so I can't see it working this way at all.
Or am I misunderstanding your comment?
Time to clear this up anyhow ... where are u Bob? lolopcorn:
I believe the smarty saves whatever software is on your truck at the time you upload the smarty. So it only saves the lastest version you have on your truck. It can only hold one program. smarty & ecm.
from what I have read, smarty uses the latest stock software capable from Dodge. if there is something new that comes out, it may take a bit for the new software to show up on mads site. so if you did have a flash done, load smarty, then go back to stock, the software load you will have is what is loaded on smarty, not what was loaded on your truck at the time you loaded a smarty software. Basicaly, if you had the latest flash from dodge, and you upload smarty. . .it's gone.
tia
