Anyone? :confused013:
Replaced VB and rebuilt TC, governor pressure solenoid and a few other things.I dont think updating the smarty will do anything. Do you know what they replaced in your trans?
So even with all the aftermarket tranny stuff you've got, you still have the problem?I assume you have a stock valve body. The smarty increases the line pressure causing the gear hunt. I just ordered the following, it claims to fix the issue. I hope to have it installed in the next couple weeks and will let you know.
Dodge "RE" Governor Solenoid to GM
Pressure Control Solenoid Conversion Kit
#REC. This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions. Added 9-25-2008. Cost $149.00
PATC 46RE 47RE 48RE Transmissions, Performance Transmission A518, 518 is about 3/4 way down the page
Maybe i'll just do that and see, cause i never have updated, just wonderin if i'll still be able to roll come coal every now and then?Mine actually shifts better with the smarty-jr than without. Doesn't gear-hunt as much, shift points are higher in the RPMs, and when needed only drops down one gear when pulling a grade rather than dying in OD then dropping two gears like it did stock. I have the 5.08 version the software. Software upgrade is free, certainly worth a try.
Set the Timing to 4 (which should be similar to what you have now) and romp on it, yeah it will create a nice cloud.Maybe i'll just do that and see, cause i never have updated, just wonderin if i'll still be able to roll come coal every now and then?
The Smarty does not increase line pressure. These tranny's are not ECM controlled. The only way to increase line pressure is to make a mechanical adjustment or install an after market V.B.:thumbsup:I assume you have a stock valve body. The smarty increases the line pressure causing the gear hunt. I just ordered the following, it claims to fix the issue. I hope to have it installed in the next couple weeks and will let you know.
