1 - 1 of 1 Posts
I have a Smarty JR w/ME installed on an '08 6.7 and just finished a TBE DPF delete. Started to delete the EGR and discovered the EGR valve assembly block off plate is defective. My question is can I continue to remove the cross over tube and install the block off plate on the cooler side. Then remove the EGR actuator motor and pull out the actuator, unplug the throttle valve connector and leave the EGR valve assembly installed without any problems. If so, should I leave the actuator motor removed or reattached to the valve assembly. I plan to run like this until a replacement plate is recieved. Truck is a daily driver and I need to drive it until the parts come. Thanks
1 - 1 of 1 Posts
