Just Reseaved My Smarty S06, Installation Instructions Say To Not Install Unless It Has Stock Ecm,but I Had A Dealer Ship Adjust For My Tire Size About 3 Years Ago.33'' Will The Smarty Over Ride All Of That Or Do I Need To Get A Dealersipe To Set Perimters Back To Stock On The Ecm?[/list]
Tech Specialist
no problem. . .what the problem will be is if there has been another programmer installed and not taken off.
load her up and watch the rear tires melt
It Was All Done From A Factory Diagnostics Programer, Other Than That The Ecm Is A VirGin
Banned
What they mean is, like said, an aftermarket programmer...aka, Bullydog, Superchips, etc.
You will, I think, lose your tire recalibration.
Tech Specialist
tire cal. is done through ABS, when you update the ECM with smarty it will not touch it. unless you want to change your tire size ;)
