I just installed a 2004 5.9L CR into my 2002 Ford F350.. I need to retrieve the VIN from my ECM to give to Bob. So today I put battery power to the truck and all seems good. I plug in my Smarty S06 to the OBD port and the Smarty turns on like it should and after going thru the start up process, its comes to a screen that says "update ECM" or "Retrieve DTC".. When I select the update (or really any selection) it goes to a screen telling me to turn key off and press > then turn key on and press > .. I do that like 5 or 6 times and nothing happpens other then it keeps telling me to turn key off or on.. What am I doing wrong?
I tried calling Bob but have not heard back yet..
Thanks in advance!
Hide your cats!
where did you get the smarty?
Discussion Starter #5 (Edited)
He is having a wiring/communication issue. We spoke last night
Yep I ended up having a wire that wasn't making a good connection. Once I fixed that, the Smarty is good to go! Bob is getting me a recovery file and that should help greatly!
Thanks for taking the time to help me over the phone Bob :party018:
Here is more info on my swap with pics
