1 - 4 of 4 Posts
can i run a smarty stacked with edge and a mp8?
Yes Just keep the rail pressure at a minimum with the Smarty since the MP-8 is adding its own. As far as the Edge goes, if it has the timing option set it to stock and use the Smarty for your timing. If it doesn't have the timing option, you need to turn down the timing on your Smarty.
As far as I know...run the even catcher settings if your edge doesnt have a timing option. Me and Compcowboy know a guy who stacked his timing..and ended losing his motor.
I know some guys do it. But when I get my smarty Ill run no rail pressure(because of MP 8), even catcher settings and edge hot, might play with torque management.
:thumbsup:
Will the smarty and Edge stack really add any power over just the Smarty turned all the way up or will the Edge just be a good set of gauges?
1 - 4 of 4 Posts
