So I just bought a 2007 6.7. Driving it this week for the first two or three times I brake at a corner it sounds like the abs is engaging. This morning it almost felt like it was coming from the transfer case and tranny area. It only happens at very low speeds almost at te same time it downshifts into 1st. Any thoughts???
· Mr. Vehicle Destroyer
can you feel any feedback in the brake pedal? or is it just audible noise?
It's both audible but also can feel it. Not alot, but I can feel it. No vibrating in the pedal though. Hard to discribe the "feel" though.
OK, is it more prevalent in a left or right turn?
What you are describing almost sounds like a hub bearing starting to go bad. or a 4x4 u-joint.
It's not when I turn. I should have specified. Only happens so far stopping Ina straight line. And only happens once or twice. After that it doesn't happen.
rust on the rotors from sitting.... probably a non-issue.
