1 - 4 of 4 Posts
I have an 06 1 ton, the problem is at 50-60 when you hold the pedal steady it starts to surge almost like its missing. Dealer put in new drivelines front and rear, checked the tires and got another dealer to check it. Other dealer thinks it's the torque converter which he says is common. The truck only has 21,000 miles...this has been going on for about 3,000 miles.....anyone have a suggestion or have had this problem??
Thanks
watch your tack when it starts to surge..try running with your overdrive off and see if it makes a difference. mine did that and it was the clutches..
how often do you change your fuel filter
Surgin
Thanks I will try it with the overdrive off. I have watched the tack but I nor the tech could really see it change. When you say the clutches you are refering to the ones in the torque?
Any update on this issue?
1 - 4 of 4 Posts
