1 - 3 of 3 Posts
Over the last month or so I've noticed a puff of light blue smoke when first started below 40 degrees. There's also a light haze in the exhaust for the first 2-3 minutes. After that it's gone. There's no smoke or exhaust haze at all once it's warm. I do know that I have some play in the turbo shaft and I'm thinking the turbo may be starting to show signs of wear and tear. Does this sound like the turbo is leaking oil into the exhaust or could this be something else?
Three thousand miles ago I replaced all 6 injectors with new stock Bosch injectors, adjusted the valves and added a 2 micron fuel filter between the stock fuel filter and the CP3.
1 - 3 of 3 Posts
