1 - 9 of 9 Posts
· VA Chapter VP
hey guys last year i pulled with 12/32 tread tires of bfg allterains 33'' well I want to get better traction tires this year i can afford brand new ones does anyone have any suggestion for what to by. thanks yall
Depends on what types of tracks your pulling on seems like everyone is using either BFG All Terrains, or TRXS STS or a combination of the two
· Second Most Important Member
most guys run bfg's on our dirt
STS on clay/sand and BFG A/T on dirt/sand. But in the end, it's what works for you. If you ran A/T's last year, and want more traction, you may want to run some sort of M/T's this year.
Edit: Are you pulling in Madison this year? I can't find the rules?
· VA Chapter VP
i am pullin at morgans corner in NC and i am trying dinwiddie and petersburg for nationals if the truck holds up. so i may go do a combo deal with possibly 8 different tires
There's a wide range of tires that you can run. I dont run diesel, but I pull in Prostock 4x4 gas. you can go for a more V style tire like the 4WD Mod truck run. If you run a smaller tire (suggested, smaller tire = more rotation) a more cost effective version of the Mickey Tompson Baja Claw is the Yokohama Geolandar M/T Plus.
Or if your looking for a tire with more surface area, less bite, but a lot of tread, the Mud-Terrain T/A KM2 looks good. (I've never used it, just seen it)
Other options are the:
Dick Cepek Radial F-C II
Goodyear Wrangler MT/R with Kevlar
BFGoodrich All-Terrain T/A KO
Good luck, and happy pulling!
-Sarafin
Everybody around me runs fierece attitudes they're pretty cheap and look good
I'll probably go to Madison to watch this year, won't be pulling cause it was dropped as a points pull. Usually always a good turn out of trucks there tho.
1 - 9 of 9 Posts
