I just bought hi flow dv's and need a turbo. I was wondering if i could use a S400 or a HT3B as a single for now, then when i get a better head gasket and studs i can use my hx35 for a twin setup.
Tech Specialist
Not sure what the specs on an ht3b are but the spin backwards and a 26cm housing is way big.
An s465 with a good housing is similar to a silverbullet (about what BD uses in there towing twins for the primary), but once you use it as twins its going to be a little small IMO.
you will never get a S400 to lite with a 12v on the street with what you got to work with. run the 35 you got and save for the twins. the biggest you would what to go on your set up is 62/65/14 or 62/71/14. my 96 has a 215 pump,4k spring, cut dv's,holders, #0 plate,370's and for a turbo, a 62/71/14. it lights OK, egt's stay good when pulling my gooseneck(14000lbs) boost get to 53 to 56psi. but i have a built auto with a lose converter to help spool it up. with a 5 spd it will be a little hard to keep a big turbo lite on the street.
