1 - 3 of 3 Posts
I'm in hard spot.. Which turbo setup should i get? I see 1600 with temps quite easily with 36lbs of boost on stock turb.. Which turbo setup will keep em down and will produce the best? I need some experianced input.
Thanks.
03 quad cab, 6 speed, SB dual disc, 150 lift pump, 4-5 inch straight, no intake yet, diablo predator, pyro and boost gauges, 60 hp stix, leveled with 35s awn ittt
A wise man once said- go big the first time. So I will pass that on to you.. If you think your gonna do twins. Go ahead and do them so you dont spend extra money on buying mutiple turbos like everyone else does..lol:thumbsup:
Diesel sniffer
I would NOT use your stock 341 in a twin set up, it's too small. Even a 62/65/12 or 14 (as a single) would be a giant step up and still spool great. Oops, just noticed you had 60's, I'd jump to a 63/68/13, that would keep up with your fueling fine.
1 - 3 of 3 Posts
