1 - 20 of 32 Posts
SUPER MODERATOR
who knows if this ring is in the turbo or did my cold air intake get rid of that already cause i didnt notice anymore noise after i put my volant on thanks all.
SUPER MODERATOR
is it hard to take off or should i let a shop do it is the second thing:thumbsup
SUPER MODERATOR
then it comes out in the morning if anyone has pics or can tell me how to do it since i dont know what it even looks like its my first cummins iv messed with
Just take off your intake tubing.. then look for a metal ring with a little gap (this is on the turbo) get some needle nose pliers and pop it out then the metal cone ring should slide right out then your set :thumbsup
Take your intake tube off our turbo, and take a scew driver and VERY carefully get under the compression ring and roll it out of the grove and presto... it out. simple
SUPER MODERATOR
does the ring have to go back in after sorry for all the questions but this truck is my baby dont want to hurt her lol
no sir it does not but keep it just in case you want to put it back in someday... also i got a check engine light after i took it out but it went away after a while
No, just put the cone and the ring in a safe place... just in case you want to put it back in.
SUPER MODERATOR
Discussion Starter · #11 ·
thanks guys
Heres a good pic of whats going to be coming out :thumbsup
A silencer ring is a metal baffle placed into the turbocharger inlet to reduce whistle from the turbocharger. It is installed in Ram truck engines at the request of Chrysler. The silencer ring has no effect on engine output, EGT, or boost levels.
Removal:
Remove the flex hose from the front of the turbo that goes to the breather. Just inside the turbo, you will see a snap ring that looks like a piston ring (charcoal color), very gently with a small flat blade screw driver, lift one end of the snap ring out of the groove, then continue to work around the snap ring, lifting it out of the groove. When the snap ring has been removed, you can easily remove the silencer ring.
Image on left is WITH the ring. Image on the right is WITH OUT the ring.
SUPER MODERATOR
Discussion Starter · #14 ·
looks easy thanks guys if your ever in edmonton alberta i owe you a beer:beer
So other than the sweet turbo whistle, removing said ring does nothing performance wise? I love scaring moose and deer while flying down the highway!!
Thanks, just went out and took mine off too, mileage went down a little, right foot just got a bit heavier. Sounds a lot better.
It makes the whistle alittle less refined but it makes it much louder. At the competition diesel forum site some guys are saying that dyno tested they had proof of 7 hp gain. But i didnt notice a thing so im not sure i believe that.
A few weeks ago I was talkin with a buddy of mine and I told him bout the silencer ring removal. He said he had never heard of doin that before. So since he has an aurora 3000 on his 04' we ventured into his garage to take a close look at his stock holset off the truck and see what would be involved in removing the ring. Removal was easy, but after looking into the turbo it seemed that doin this might actually hinder the proficiency of the turbo. With the ring on, it kind of funnels the air into the turbo from the intake, with it off there are multiple openings that surround the wheel (you can see what i'm talking about in the pics below) that appeared to me would create turbulence when the turbo is drawing air in at a rapid rate. I was going to remove mine but am thinking twice about it now:confused:
1 - 20 of 32 Posts
