i've seen a lot of guys sig's that say "silencer ring mia". ive worked on big trucks most of my life, but i have no idea where or what to look for. if it makes that much of a difference in power, sound, and/or hp, i want mine gone. any info is appreciated....
Paranoid
its all about sound... no HP gain. Search function is your friend on this site
Ring's gone
My dodge is my first diesel---my "hot rod" I could never afford when I was young so to speak. Your silencer ring is on the air box side of the turbo. When you take the tube off you can see a 3" diameter "snap" ring in the inside of the turbo inlet. This is your silencer ring- can remove it w/ a flat screw driver (that's how I did it) and to be honest- it doesn't make a HUGE amount of difference in the sound nor the hp. (yes ran mine on the dyno at a dyno day 2x). You probably know a helluva lot more about how to make power with this motor- Good Luck.
World Champs!!!
"Silencer ring MIA" in sig=space filler for when you have no mods :rof
thanks guys. didnt want to sound ignorant, but i didnt know... i can make the big (15L) common rail engines sing a song, getting the hang of these little ground pounders. same stuff smaller package... thanks again.
