Hi Cumminers,
When I started my '03 Ram 3500 after it being parked up over Winter, I've found that both my front signal lights / indicators have stopped working, along with one of my rear indicators, left low beam & right high beam headlights.
I read on a quick Google search that it might be the steering column multi function switch (indicators / headlight low & high beam / windscreen wipers).
I'm in the process of getting to the multi switch to see if it's worn, but wondered if it might be anything else.
These trucks don't seem to have any fuses or relays for the headlights or inductors.
The bulbs seem to be OK in the headlight cluster, and my voltmeter says there's no voltage at either the headlight bulb socket or the indicator socket, once the bulbs are removed.
When my Hazard light switch is on, I still only get my rear right indicator coming on.
Any suggesting would be greatly appreciated.
Thank you.
Regards,
Daf Tekno
I've checked my entire fuse box.
It has no fuses or relays for headlights or indicators.
Nothing that's labelled anyway.
Someone mentioned that because this truck has a computer controller for the electrics, it doesn't have the usual fuses and relays.
Hence my request for help.
