While cruising at 55-60 MPH if I let off the pedal slightly-not all the way- and then depress the pedal normally to speed up, the truck shudders for a second and then all is fine. Is bad enough the passengers can notice it. Actually shakes the truck fairly good.
If you let off the pedal fully and then depress it this never happens. I need to be a straight level road and can duplicate the problem.
Engine RPM's do not drop of fluctuate. Does not seem like the torque converter is unlocking and locking, but possible.
Took it to the dealership and they could not duplicate it. They updated the trans controller and the problem is still present. I'm sure I will need to drive the truck for them to make it happen.
Curious if anyone else has experienced this or knows what it might be?
