im running a bullydog pmt but can get past 26-28psi...should i order up a boostfooler...also anyone with the pmt-how mutch boost r u making?
What year is your truck?im running a bullydog pmt but can get past 26-28psi...should i order up a boostfooler...also anyone with the pmt-how mutch boost r u making?
Hmm...that seems a little low...even without a boost fooler you should be in the 30s no problem....its a 2006
I think the puck does some boost fooling. Could help.wat about a powerpuck with my pmt?
is that puck worth it? for what i havePowerpuck is fuel pressure only on 3rd gen's, no timing or boost fooling. If the problem is not mechanical, I would go with the X2 or just a Quad boost fooler. I have tried them both and they are very good.
No, that sounds pretty reasonable. My juice won't read over 20psi when I stacked it with my ramifier. Where does the pmt read the boost, the map or mechanically?I know this might sound crazy but stick with me a bit. When I stacked my Juice with the X2 all I could hit was 28 PSI tops. Reason being is the boost fooling on the X2 screwed up the readings on the Attitude. Could it be a bad download on your Bullydog?
I see the same with my PMT. It could be boost foolin because your getting the boost reading from the PCM. So I thought maybe the motor sees more boost but the PCM does not. You would need a machinical guage to know for sure. I tought about calling BullyDog other it. Let me know what you find out.im running a bullydog pmt but can get past 26-28psi...should i order up a boostfooler...also anyone with the pmt-how mutch boost r u making?
not a bad download. i just updated it with the new version. does it now and on the old version.No, that sounds pretty reasonable. My juice won't read over 20psi when I stacked it with my ramifier. Where does the pmt read the boost, the map or mechanically?
