1 - 1 of 1 Posts
I have a short and used a test light and i have a ground in my power wire at the fuse box number 35 15amp for cluster. I have narrowed it down to the point it has to do with the dom lights???
If i disconnect the harness at the pillow driver side the short it gone. But not the crazy part is i checked the harness and took it out and everything looks ok.
If i have the dom lights all off with the bulbs out there is no more short and the cluster works fine without a short. But out of the 3 dom lights in the cab if i put the bulb back in any of the dom lights and turn it on i have the short again.. So im guessing it doesnt have to do with one of the dom lights itself but somthing to dow ith something i cant figure out . Now idk if its before or after the harness at the pillow inside the cab idk if there are relays or anything.. Also disconnected the switch that controls the headlights and dom lights/ cluster lights and still had a short when i turned on a dom light
1 - 1 of 1 Posts
