1 - 11 of 11 Posts
2004.5 1 ton srw 4wd
I’ve had a 3 inch level on the front of my truck for a while and I finally got around to getting better shocks for it. I’m just curious if I go ahead and put the new shocks on before I get longer control arms will the top mounting stud on the shock bend since the axle is being pulled back towards the cab? Truck is a 4wd
you don't need to get longer control arms, but to answer your question, no, it will not bend the shock, they pivot via the eye-bolt on the bottom.
would longer control arms help the ride? If I don’t need them I won’t get them but it rides horrible right now.
There are sooo many things that can contribute to ride quality on the front end of these trucks. So in a nutshell, no.
Control arms will center your axle in the wheel well so you don't rub, but you aren't going to notice a ride quality difference if that's all you're going for.
agreed, no noticeable change in ride when I replaced my control arms. My bushing were pretty trashed and the stock ones are not much cheaper than THuren/Carli etc. No need to replace them though if you aren't trashing your truck off-road and they aren't worn out.
2006 Megacab
CJC offroad might be able to help you out
good coil springs and shocks, sway bar and long arms for best ride quality changes.
Discussion Starter #8
Right now I have carli front shocks and bilstein rear shocks I am getting ready to install and I just ordered some extended sway bar links.I’m thinking about some thirteen springs up front too. I don’t care if it rides great or not but anything has to be better than what it is.
With a 2.5" level I found a stock length end link rode drastically better than an extended one. Ideally the sway bar should be closer to level and even the shorter extended ones push it way up.
Discussion Starter #11
I just put my front shocks on and realized my sway bar is actually pretty close to level. Guess I wasted $80 on the links
1 - 11 of 11 Posts
