1 - 3 of 3 Posts
95 with auto
I need a schematic of the steering column on my truck.
The problem I have is the lever is loose inside the column. I've traced it down to where it connects to the lever at the bottom of the column. I can hold the lever/linkage that goes to the trans and the selector level inside the truck moves up and down 3-4 inches before it wants to move the shift lever/linkage.
I'm assuming it must have some type of worn out or broken coupler where the shaft connects to the lever.
Anybody know what's inside the column or have a blow-up of it?
Thanks, Dave
Discussion Starter #2
Anybody?
How does the shifter shaft that that goes through the middle of the steering column attach to the shift lever that comes out of the column down by the firewall?
Dave
This one is a rare problem so I think you are on your own to find out what is wrong. Maybe you can post what you find.
1 - 3 of 3 Posts
