I have an '06 with the 4 speed auto and really like the vehicle on the whole. One thing that I have hated from the beginning of ownership however are the factory shift points and TC lock-out controls at low throttle position without tow/haul active.
Is there a tuner that allows shift point modification and lock-out adjustments?
I'm looking for a 4th gear lock-out around 40mph when under 15% throttle. I'd also like to drop the engagement RPM of a couple shift points again, only under 15% or 20% throttle.
I think Dodge did a great job with the action in tow/haul mode, but what a disappointment for around town driving.
Anyone agree with me and found a tractable solution?
Thank you.
- Stump
Fill Diesel Only
I am I reading it that you want have the TC lockup sooner?
I have not heard of any type of programming to alter shift points. At least my tranny shop knows nothig about it. There is the option of putting a TC lockup switch, which I have not done yet. Was actaully plannig on doing it today as its storming here and I'm bored. There is a writeup on how to do it. Basically taking one wire on the tranny and putting a switch between it and ground, will lock the converter manually. I think I read that on our truck it will only work once in second. If I get on my :butt: and go out to the shop I will know in about 10 min. I have the switch in place and grounded. Just have to tie in the wire on the #7 pin.
Banned
Rumor was/is that Smarty may be modifying shifts, in the future but...who knows. Aside from that, there is nothing. I just drive the truck in tow/haul all the time...
You know, that is one of the first questions I asked MADS before I decided to order a Smarty. They said, not yet but we are looking into it for the future.
MADS Electronics is going to do great things for these trucks. I just keep my fingers crossed that it happens sooner than later.
As far as the switch installation goes. I really have no interest doing anything outside of the computer. The computer is the 'brain' of your vehicle. Anytime you bypass it, you introduce a variable that is not under consideration while it calculates the system outputs. I would consider a valve body though as it remains integrated.
I just didn't know if there was a solution to this problem.
Also, I did not proof read the title of my first post and spelled point - "poing"... how do you delete a thread?
- Stump
Banned
- Stump
Mods have to do it, though I'd recommend leaving it for future reference :w:
As for TC lock-up...there's nothing wrong wiht installing one BUT you risk breaking the stock input shaft if you leave the TC locked for shifts....
Exactly my point Awenthol. If you bypass the computer, it doesn't have all the information required to make the correct decisions. You essentially enter a new variable into the equation. Last time I checked, if you have 2 variables, you need 2 equations to solve. The second equation is you remembering or being quick enough to flip the switch before a shift.
The only human variable I want in my truck is remembering to change my oil.
- Stump
Foo-ey on Dodge and hurry up MADS!
