Shift Enhanser
Charles, we get a lot of questions on this product so i can give you guys a heads up .
As many of you know the 2005 - 2007 Dodges do not have a kick down cable. What they have is an electronic actuator on the side of the transmission. The primary function of the shift enhanser is to give you give you a cable adjustment . It is done electronically rather than mechanically.
It does offer an advantage over a mechanical cable for those that want to drag race as you can use it in race mode and have a very agressive throttle setting. This helps prevent the burning up of the rear clutch packs during launch.
HOWEVER , the primary function of the Shift Enhanser is to help get rid of the 1 - 2 shuttle shift and the 2-3 flare.
Caution : Right from the factory , some of these Dodges have a bad governor pressure sensor. The Shift Enhanser cannot correct symptoms caused by a faulty sensor.
The oem part number for the new governor pressure sensor is 56028196AA
( sometimes the AA on the end of the part number, changes to ab or ac as Dodge get in new batches but the numbers remain the same. )
Very often techs will change out the governor solenoid and it is not the one causing the 1-2 shuttle shift issues. The oem part number of the governor solenoid they often change is 4617210 .
The shift enhanser is a programmable box, so no matter the make of VB, whether it be DTT , or oem , or aftermarket we can program them accordingly.
