replacing my clutch and got the transmission out. the seal is leaking atf so i figured id replace it. anyone got a guide?
Well what i did was i took out the four bolts or so thats holding it on then if you cant pull it off tap it with a hammer a little bit and it will come right off. Then what i did is i took some ultra grey gasket maker and used a sh*t ton on it and then put it back on evenly and take the bolts and put em back in and snug it up real good!
Reactions: Broke Down
be careful taking this seal out, you can easily crack the tail housing. be gentle and take your time, just like roolinsoot said you can take it off and easily knock it out from the back.
edit: rollinsoot, i'll give you your first thanks for that one :thumbsup:
Or is it the seal at the very end where the slip shaft slides in? if it is there, its simple. just take a small screw driver, or chisle and get under the old one and pry it and and simply tap the new one in evenly.
thanks.:party018:
