:umno:if you really want something to clean it run some power source threw it...:thumbsup:
Don't want the ocean in my truck and we know foam in fuel is very bad.
:ditto: i don't put it anywhere but in my oil.....every old gasser truck/jeep i've had, first thing i do before i change my oil in it is drop a can off in her, let her run for about 5-10min, shut her down, change the oil, filler her up, drive it for about 500 miles, change the oil again, then just do it every 3-5k....Seafoam is actually a very good product for gassers and dosnt hurt diesel either..
I agree it doesn't do much for diesels but it does work very well in gassers. :thumbsup: Use it in my wifes 06 Durango and my buddies truck and bayliner. It gave us all a noticeable difference. :thumbsup:Your diesel doesn't need it. Not sure does much for gassers either. Not putting anything in "brake booster line" either. For a gasser that would be directlly into intake. Diesel with 'hydroboost' has no such line. Change your fuel filter and you have cleaned the fuel delivery system. Cause the filter and bottom of fuel tank is only places you will find trash unless you have a crappy screen inside a banjo bolt or added something.
i've never used it except in my oil....and it made her clean as a wistle...:lol4:....so if you want to use it in the oil i vote yes, for anything else...i have 0 experience with it....ok, so, would you suggest it, or, should i jes save my ten bucks for somethin else?:confused013:
