1 - 12 of 12 Posts
SUPER MODERATOR
hey guys i just had me egt hooked up but they put it after turbo idiots now i dont know what the safe limit is i thought it was 1300 before the turbo but have no clue with the after temp
Add 300* to your reading, that will get you close. That is around the difference from pre to post.
SUPER MODERATOR
I hit 1050 figured it was ok thanks bbram you help me out again
SUPER MODERATOR
Like stated...it'll get you close but IMO, plug that SOB up and move it to the manifold :w:
it took three weeks to get it in for them to mess it up itll be another 3 to get them to fix it there reason was they didnt have a 1/8 pipe thread tap so they drilled into the pipe behind the turbo and used a 5 inch hose clamp to hold it there
SUPER MODERATOR
pre turbo man that gives you the best read my shop just messed up and put it behind the turbo
SUPER MODERATOR
Discussion Starter · #11 ·
i dunno guys does 850 sound right doin 75 on the highway empty with my diablo preditor on performance :w:
1 - 12 of 12 Posts
