dang what kinda fuel you running?
Run your 66 firstSo I was doing some chating and got a general concensus from several guys that a S480 is not only too small, but WAY too small to go under a 66.... they said to look at something in the 88mm range as a bottom snail... they told me the S480 is an 80mm... so what frame is the 88? Still a S400 based turbo or what?
Has this set-up been done enough for there to be a "kit" per say, as in piping? Really any info on an 88mm turbo or something suitable to go under my 66 would be appreciated.
No vp can fuel enough to need bigger than a s480 IMO.
Edit, justread your above post...66/480 is big air, and will make a high hp p pump truck
If you go by a 2:1 compound ratio by CFM, the 66 needs a S591 to do that.That was my impression too, that adding a 480 would be a big set of twins... and I know you have to take everything with a grain of salt... but it wasn't like they said; "Oh thats a tad on the small side.".... they were pretty adamant about it being "way too small".... which kinda took me by suprise, hence why I'm asking for second opinions.
I understand you saying run the 66 first, but trust me... it'll only be a matter of time where I'll want to take the truck to the next level(not saying that'll be a week after I get her all put together). So I'm a tad pre-mature of the research for twinsbut you can never know too much!
