1 - 20 of 26 Posts
Anyone running this turbo on the street? How street able is it?
What pump are you running?
Not really the best street turbo but its almost at the highest spot you'd want in the rpm. The biggest single I'd like in the s400 frame would be the 471.
Discussion Starter · #10 ·
no. more due to the fact that edge dumps fuel down low. timing wasn't the issue. you can not get enough timing with a vp.
So your saying once the turbo lite, the edge lacked feeding the fuel?
Never ran an edge but im guessing that the edge started fueling early (low in the rpm range)
Its set to defuel around 3200-3400 rpm. Where the tst is around 36-3700.
High 20's....27 max if i recall?
Discussion Starter · #14 ·
ohh gotcha. so would it not be worth running a turbo like this with the edge?
no. firemed is correct. the edge slobbers fuel down low too soon causing a delay in spool and excessive smoke. and i didn't like having a 1200rpm power band.....2000rpm-3200rpm. tst/ts mvp was by far more fun to drive and less smokey.
off-road. i ran mine with tst pm3/ts mvp. then tst comp/ts mvp. tst comp/edge and then edge juice w/attitude hot. edge flat out sucked. no idea why everyone preaches them.
24* max firemed out of a so anyway
1 - 20 of 26 Posts
