What is changed to make an s400 to s475?
:agree2:S4 is the series, s4XX, the x's typically being the inducer size. S475 would be an s400 with a 75mm inducer.
So the inducer is the compressor side wheel?S4 is the series, s4XX, the x's typically being the inducer size. S475 would be an s400 with a 75mm inducer.
Yes and no. Both the compressor and exhaust wheel both have a inducer and exducer. The first place air enters the comperssor is the inducer, and where it exits is the exducer. Same idea for exhaust where it enters is inducer exit is exducer.So the inducer is the compressor side wheel?
So if your s400 has a 75mm compressor wheel is it a s400 or a s475?Yes and no. Both the compressor and exhaust wheel both have a inducer and exducer. The first place air enters the comperssor is the inducer, and where it exits is the exducer. Same idea for exhaust where it enters is inducer exit is exducer.
That would be a s475.So if your s400 has a 75mm compressor wheel is it a s400 or a s475?
Got it thanks!That would be a s475.
x2......:thumbsup:good diagram:thumbsup:
