I have got a 2012 dodge 2500 6.7 it has 104,000 miles on it the truck has been running good and now it has started running hot for some reason the first time it ran hot I replaced the thermostat it ran fine a couple days done it again replaced again ran hot took to the shop they put a mopar tstat in it and changed antifreeze and said had an air pocket in it stil wants to run hot I have been in 20-50 degree weather for a little bit now and soon as you crank it up after sitting all night it’ll warm up to about 140 and the heater is hot that’s warmed up for 30 minutes when I drive down the road heater starts blowing cold temp starts going down to 130 or so but will slowly work it’s way up to 170-190 and heater works good you can stop at a red light temp goes down to 160 or so heater gets cold leave the red light warms back up the only time it will run hot now is if you really gas on it to pass someone or something then the heater will get ice cold and the temp will shoot up to 220 you can cut the truck off and let the air off the radiator cap and it’ll go back down and heater will get hot again been driving the truck a month like this just drove it 3 straight hours doing 70-75 and ran perfect as long as you just cruise in it the mechanics said it might have a slight crack in the head but there’s not smoke or water in radiator and I’ve done the combustion gas test on it and it never changed colors so I thought I’d get on here and see y’all’s opinions?
