1 - 20 of 36 Posts
The turbo went out on my 07 5.9 a couple weeks ago. I replaced the turbo charger last night it started up fine when i got on the road and it came into boost it started to accellerate uncontrobily:shock:. I killed the key and got on the breaks hard. It was still trying to accellerate and i was running out of road. so i put it into neutral and it quickly came to a stop but the engine was deep it to redline befor it shut down probibly nearing 5000 rpm the motor is now seized up but what the hell would cause it to do this.
thanks in advance
Man that sucks what caused ur turbo to blo w the first time
· TECH SPECIALIST
oil in the intercooler from the turbo... Someone else had this happen in recent weeks... while it's too late now, maybe a quick way to kill the motor would be to cut one of the boost hoses. Not sure if it would work but that wold be the 1st thing I'd try.
:shock: Pretty sure I wouldn't want to be standing next to it or bent over iunder the hood......Rods flying scare me :hehe:
Sorry Man.
That sucks.
You should have cleaned the intercooler and intake pipes before going out for a test drive..
Discussion Starter · #13 ·
it never crossed my mind that oil could explode under the right conditions live and learn i am in luck a friend's dad has a motor from an 06 it should bolt right in yes no?
Sent from my XT897 using AutoGuide.Com Free App
· Rescue Tower
Guess you never noticed some of the guys that run WMO. Usually in the older 12v engines. Not a lot of difference between oil and diesel either. Expensive lesson.
man that sucks.
Yea the oil that is in the intercooler will get picked up and turn into a fine mist. And off to the races it goes. That sucks man a I have seen older semi trucks run away on grain dust if it is dusty enough and fine enough. In side a elevator. The bad way they can gain RPMs so fast it's to late if you can get it shut down
1 - 20 of 36 Posts
