says there are no codes so they need to charge me for the diagnosis. The truck idles rough in or out of gear. It started idling rough after the dealership replaced the injector and injector wiring harness under the valve cover. I also just had my torque converter replaced about 1000 miles ago but seeing it idles rough both in and out of gear I am eliminating that from the check list at this point.
No white, blue or black smoke. I don't have my tuner turned on (stock settings). The truck just shakes while it's idling...shakes enough for my 8 year old to ask me what's wrong with the truck. It's not a vigorous shake but enough to where you feel it shaking in your back and when you open the door you can see the door actually shaking up and down moving about 1/2 - 1" Is this normal?
Anyone have an idea, I've called the chrysler support line and they are going to call the dealership to see if they checked the compression after the injector replacement (which they didn't). I know I'm throwing alot out there but are has anyone had this and possibly know what the problem was. I don't feel too confident about my dealership at this point.
