i just changed my headgasket and put in studs. on cylinder 3 the intake rocker arm was removed before and got stripped. they used a helicoil to repair the threads. when i torqued that bolt it pulled out the coil. i then drilled it out and put in an insert supplied by the local machine shop. the metal of the insert got stripped by the bolt when i went to torque it< which is only 27 ft-lbs> does anyone have any suggestions on how to fix this. thanks.
What kind of insert did the machine shop install? I used to do this stuff quite often, there's no way a competent shop should have this happen if they used a proper insert.
You can buy a bigger Helicoil that will allow you to replace the striped insert and use the factory stud size.
i dont know the exact metal but the factory bolt stripped out the inside of the insert when i went to torque it. the insert came out of the head fine. it is metalic but i can scrape it away with a knife. it seems real soft
that is what i did for the most recent try
I have almost the same issue.
The metal of the insert got stripped by the bolt when i went to torque it< which is only 27 ft-lbs> does anyone have any suggestions on how to fix this. thanks.
They should only be Torqued to 18ft-lbs! Did the insert work well? Are you running 110Lbs valve Springs?
