1 - 9 of 9 Posts
I’ve been adjusting the ve some today to get everything possible out of it. My son and I turned up the fuel to the point of runaway, then backed it off to where it returns to idle after a short wot rev. I feel like it’s good but while I’m standing here (still shaking from how hard it is to kill the engine when running away) thinking could it runaway while out hot rodding the truck?
It shouldn’t.... but I like to go on a test drive with the intake off and a friend in the passenger seat with a shutoff board in hand. I’ve never had an issue as long as it’s not tuned to the point of rpm hang. Just my personal experience
We did just that. Truck ran great with no issue. Thanks for the advice!
Unfortunately I may have outgrown the ve... need mo powwa!!!
Naaaa you have a way's to go Bud . you only have a 518 you will destroy that before needing more Power :) I'm well above you and got smart and went 47rh that will be your Next Money Dump LOL .
^^^^this..... I’m in the same boat, I’m on the hunt for a 47rh currently but they are pretty hard to find. Of course when I didn’t have the money I’d see them all the time!!!!!
You want a built one ? I can help with that if need be .?? Message me
Val
Me... I’m ready fo moa fo shoa hahaha
My setup is: 93 12v, studs, maxed 12mm ve, fuel pin, m&h timing device, skipped a tooth timing advance, 5x14’s, he351cw/s475 compounds, fass 165gph. Transplanted into a CCLB super duty, zf6 manual trans, 850hp rated DD clutch, 488: gears, 40” tires, ladder bars.
This was my ultimate/dooms day truck project. Truck will do bout anything. Tow heavy no problem. Rip through the gears down the beach. Can get out the way or leave your behind pretty damn quick for its size. Roast tires, yank tree stumps and bull doze houses if ya want hahaha all getting decent fuel mileage.
The truck has never seen a shop, Ever. All work done by myself over a 8 year period with the help of friends and of coarse this forum. I came here not knowing anything. Still have tons to learn.
Reactions: simplysmn
Discussion Starter · #9 ·
I’ve been very pleased and content with the truck since the compounds done a couple years ago. But shortly after that I bought a new 4th gen 6.7 CTD for my DD. Once I deleted the 6.7 and put a programmer on it it was over. God bless the 4th gen Dodge Cummins! I absolutely love it! But the reality is I’ve almost killed the 68rfe in 20k miles hahaha so I’m driving it sensibly trying to not drop 10k on a built 68 or 48 swap. I don’t have that kine $$$ flow anyway... It just makes dollar sense to make the dooms day fummins build into a sick 700- 800hp streetable truck to feed my hp jones haha
Unfortunately, pretty sure that means p pump swap
1 - 9 of 9 Posts
