96, mostly stock, automatic, will not warm up. It was -36F this morning, pulled out of garage, idled 25 minutes, heater on recirculating mode, cab has chill off but windows fogged up. Drive 15-30 miles 50-65 mph and the highest it gets on the gauge is about 150-160— Cannot keep the cab warm. Radiator has three plastic panels blocking air flow, one on each side between radiator and intercooler, and one in the center in front of the intercooler. Fan is still on and may be contributing some. It didn’t heat well last year, but this is worse. I believe I still have a 195 thermostat in it. If the thermostat was not operating as it should, I would have a hotter upper hose. (New aluminum heater core)
I got home pulled it in the garage, felt radiator top hose- cold, very cold. Felt fill side of radiator (lower hose side) and it is warm...??? Twenty minutes later in a cold garage, I shot temps with IR thermometer. Lower hose was 75 degrees F, top of radiator (lower hose side) 62 F. The whole passenger side of the radiator was warm. Upper hose near thermostat 37 degrees F, radiator (upper hose side) 27 F.
Is this just expansion from cold coolant being warmed up? I guess it has to go somewhere as it expands and with the thermostat closed, it would have to back up into radiator. ( Upper hose has pressure)
Thoughts?
I think I’m going to have to park it for a month.
Thoughts?
