Hey guys been a while since I have posted here, but I have a 2000 24V with a HX35(14cm W/G housing)/HT3B setup on it. Hot rod VP, ARP's, Farm Boy 200's, Airdog 150, TST powermax 3, and edge ez for timing in a 99 Superduty.
I put about 10K on it a couple years ago before pushing the headgasket out at the front of the head. Head had to be decked .010 to get it flat and put a .020 Cummins gasket in it with the same studs(my mistake). Well I have since put around another 40-45k on it with no problems except about a week ago towing a 18' car trailer pushing about 10lbs of boost all of a sudden I lost heat in the cab and the temp started to rise. Pull over to check it out and the stud between cylinders 3 & 4 is laying on top of the manifold split at the base of the threads that go into the block
So I know, I should have replaced the studs, I am assuming that when I pulled the head the first time whatever ones had stretch on the front made it to the middle that time.
The truck has seen 70psi from time to time, but nothing at extended periods or probably not more than once every 3-4 months. It is mostly a daily driver that pulls my 32' trailer a couple times a month. Should I switch over to say Haisley Machines H-11 studs? It still has the stock valve springs that I should probably upgrade as well right? 110#? And I am most likely going to water/meth inject it now as well because it does get farily hot fairly quick when pulling hills which might have been a contributor.
I know it's my own fault but I guess I am looking for pointers on switching studs and valve springs.
Thanks,
-Matt
Thanks,
-Matt
