I was looking through TSB's for 96' and I found two uncorrected conditions on my 96' that match the TSB description exactly. My truck is all stock with 94k miles. Anyone have any more info on these two TSBs or info on thier technical/corrective action and verification?
02-03-96:
Creaking noise from rear of vehicle.
The diagnosis involves the inspection of the rear leaf spring assembly to verify the appropriate
number of spring tip inserts are present. If tip inserts are broken or missing the repair procedure
is detailed in the TSB.
03-03-96
8/16/96
Droaning noise/vibration.
The symptom typically occurs at maximum load and is engine speed specific - 1900 rpm for 4x2
models, 1850 rpm for 4x4 models with the truck in fourth gear and the torque converter clutch
locked up. If the problem is identified, a repair procedure involving a revised propeller shaft with
a yoke weight damper is described.
94-’96 (BR)
With automatic
transmission and 5.9
Turbo Diesel engine.
Note: ‘96 2500 club
cab, 155 WB 4x4 with
heavy duty transfer
case built after 5/9/96
have the revised
propeller shaft.
02-03-96:
03-03-96
8/16/96
94-’96 (BR)
With automatic
Note: ‘96 2500 club
heavy duty transfer
have the revised
propeller shaft.
