Im installing a Backup Camera in my truck and need to find the reverse light wire in the wire loom by the door. Any one have an electrical schematic showing all of the lighting wire colors? Any one know off hand?
The wiring by the door - don't know, but this may help you out. I assume you have the tow package with the 7 pin connector for a trailer. Remove the connector from the bumper and look on the cap of the front of the connector. Mine is labeled for each wire (brakes, turn, etc.) and view the backside of the connector for the wiring color. This same wire may be a different color by the door. Just an idea.
Hm... That is a good idea actually. I haddnt thought of that. Thanks.
I hope it works - I was a similar situation with auxilliary back up lights. Initially, I wanted to turn a switch on in the dash - long story short - I just directly wired to the reverse light wire.
There is also a website dodge hemi forum?? that has the online manual. I find that the manuals are very confusing and worse yet, if you have to go back and forth from page to page.
Banned
I just wired in new black led tail lights and it was the all white wire
Tech Specialist
this is the connector at the tail lamp
LAMP-TAIL STOP/TURN-RIGHT (BOX ON) - BLACK 6 WAY CAV CIRCUIT FUNCTION
1 L70 18WT/GY FUSED PARK LAMP RELAY OUTPUT
2 - -
3 Z928 18BK GROUND
4 L54 18WT/LG RIGHT STOP LAMP DRIVER
5 L62 18WT/YL RIGHT REAR TURN LAMP DRIVER
6 L1 18WT/LG BACKUP LAMP FEED
lets see some final pics i've been thinking about putting one in
