Sure thing!
I haven't tried this myself, but the members here say the easiest thing to do is push the parking brake pedal down just a click or two. It is not enough to engage the brake, but supposedly it is enough to trigger the parking brake sensor, so the truck thinks the brake is engaged, and the horn won't go off when in reverse.
Also posted here was a more technical and permanent fix: "All you guys need to do is unplug the 2 wire plug next to the seatbelt (drivers side, 4 inches lower than where it buckles), then put a very small wire across the 2. Leave it in there and plug it back in. This will disable the reverse horn honk, the seatbelt light, and the seatbelt ding."
