just courious on what ft/lbs that you can retourque the stock head bolts to and also what order you do them in if you are looking down the the valve cover
I agree, but there are plenty of opinions out there that go both directions. :confused013:don't waste your time... drop some studs in it or leave it alone
They are! If your going to retorque the stock bolts, atleast by new ones. I thnik there like $3.50 each. You might end up with less clamp than you started with if the bolts strech. New studs can be had for less than $400 so only $300 more than new bolts. To me thats more than worth it for the piece of mind.i thought the head bolts were torque to yeild, a la ford style but not as crappy. Thought you had to replace them if they get to the point of needing re torque. At least thats what i read. Need to find that link
