Status
Not open for further replies.
Feelings NOT Included!
This DIY pertains to replacing the CP3 injection pump on a Common Rail 5.9. It's a fairly simple process, but some folks think it's a bigger deal than it really is.
Early CR's (03-04) will have an aditional step of removing the kickdown bracket for the TV cable going to the transmission as it interferes with removing the CP3.
WARNING! Cleanliness CAN NOT be over-emphasized when installing your new pump. Leave all fuel port covers in place until ready to connect lines.
WARNING! Whenever dealing with high pressure fuel from the CP3, use caution. At idle, the CP3 is making approx 6800 psi of fuel pressure. This is MORE than enough to cause severe injury or death.
YouTube - Resurrection II
nice photos, a good read and i thought it was going to be harder when the time came.
Discussion Starter #5 (Edited)
The worst part is getting the pump back in the pilot bore of the gear housing, everything else is cake.
Put some clean oil on the o-ring and lube the pilot bore of the gear housing and it's much easier.
Once your get the o-ring past the bevel on the pilot bore, the pump will slide right in.
Make sure you don't have any oil on the pump shaft and get as much oil off the shaft bore in the pump gear as possible.
Wow, Nice write up, deffinatly easier then it looks. :thumbsup:
Status
