1 - 17 of 17 Posts
So my vp44 finally went on my 01. What do you guys suggest I purchase to replace to best work with upgrades?
62mm turbo, 150hp injectors, 150 fass lp 4"straight pipe, k&n intake no programmer
well if you want to just stick with the vp44 and not ppump it talk to jake at diesel auto power. he will get you set up.
I suggest you get an SO (standard output) VP44, they have a higher flow capacity than the HO's.
Check with the site sponsors as your choice of vendors.
Tappet cover gasket, intake cover gasket (3rd gen is supposed to fit & be better & Return T grommets.
Ed
I bought mine from DAP. Got here really quick even though they were out of stock.
Stock. i just tow. i bought sticks at the same time. I'm more than happy. I need another 8 months before i can tap the pump. then i'll be more than happy..lol
I want it reliable not fast or smokey. so i compromised
i recently did a 600 mile trip up or Oregon and i averaged 15.8 up and 16.2 on way back. That's clearly at least a 3 mpg improvement over the original pump and injectors. It had 220k on it I think when i changed it.
lol, thats too funny, 8 months, stealth cover...... just thinkin out loud
I didn't want the cover. I thought about it but decided against it. Right now without the tap it is just as good as before IMO. It smokes a lot if I turn on the box so I don't except on rare occasions.
Ed
all this and a cam sensor too
Discussion Starter · #14 ·
So thinking on just going SO vp44. Don't need anything crazy and use car for daily driving as well. Just want to make sure it can handle the injectors and the bigger turbo with the tune on it.
Remember, from what I understand, a Stealth cover may void a warranty, now. Check with your vendor. I personally do & always will deal with DAP.
Ed
If your worried about voiding warranty go with a pump vendor that allows you to tap the pump and still have a warranty. Why wait a year to be able to tap the pump. And I would go with a SO pump dont waste your money on a Hot Rod Pump
1 - 17 of 17 Posts
