1 - 20 of 30 Posts
Bleed All American!
But to order new head gasket. Just wondering what I should go with. I really need to order it today. I'm default buying head studs, but what kind? Where can I get the best deal on this stuff?
Bleed All American!
Discussion Starter #2
bump......
Go with orginal cummins head gasket and just go with standard arp studs.
With the mods you have listed. I would have the head o-ringed, use a stock 24v gasket, and standard arp studs.
Paul
Bleed All American!
Discussion Starter #5 (Edited)
Who here has replaced there head gasket? Is there really anything super important to keep in mind? Like installing the studs, or tdc? Anything like that?
Bleed All American!
also what about a cometic head gasket?
OEM Cummins gasket is what i used also i have A-1 Headstuds i like them a little better then the ARP studs
Bleed All American!
Discussion Starter #8
No orings? What kind of boost are you runing?
Stevencritt, i used FelPro Headgasket and stock style head bolts, I torqued my head down to 135ft lbs torque; I've been running close to 50psi for three years and still no problems.
A few things you need to make sure of, clean out the holes with compressed air to get the oil/coolant out of the threads, and make sure you follow the torque sequince(down to every detail). You should be fine.
Bleed All American!
Discussion Starter #10
Well yea that I won't have a problem with. I'm just a little worried about sting the valves.
Bleed All American!
Discussion Starter #11
if i cant get my head o-ringed. would yall recommend putting on a cr head gasket??
Here's my $.02 worth on my head gasket experiences;
I was running 100hp nozzles with a factory turbo and an Edge box. I could roll about 45lbs of boost outta that little turbo, then the gasket blew apart 500 miles from home in the winter pulling a trailer. What a mess!!! I didn't feel like doing the job twice so it took an extra 10 days to do the project, but I went with ARP studs clamped to 130lbs, OEM Cummins gasket and had the head o-ringed. That lasted just over a year and the dreaded 53 block cracked. New block, 150 sticks and HTT 62/71/13 turbo that rolls about 55-58lbs of boost. Well that gasket lasted about 10 months and the gasket crapped the farm. I had the head fireringed and clamped the studs to 180lbs and no issues so far 2 years later, KNOCK ON WOOD!!!! Being I live in the northern climates and the extreme cold to hot temps the engine goes through we are a little harder on gaskets than most. NC doesn't get that cold and I'd say you really don't have to go and get it fireringed, but I'd take the extra time and spend a little extra $$ and definately get it oringed and studded, especially if your pushing much over 45lbs of boost. Sure, it's easy for us to sit here and spend YOUR money, but.... LOL!!!
Bleed All American!
Discussion Starter #16
I only have a 1000 bucks to spend on this maybe a little more. So I'm just trying to make the best decision with what I have to spend.
I was under the impression that fire rings were not such a good idea on a DD.
Stay away from fire rings on a DD unless you plan on cutting the grove in the head and the block. O rings are the way to go on DD. A new gasket, studs, o-rings can be had EASILY for under a grand. Setting the valves is a piece of cake on these things. Just do a few searches and you will find everything you need to know and it can be done in around an hour or so.
Bleed All American!
Discussion Starter #19
any special tools?
i didnt use anything special except the turning tool i made cause my balancer was off. i am going to try a box end crows foot to avoid taking off the rockers when i do my retorque. my o rings complete top end gasket kit and studs were 1000 out the door dropped it off Wednesday had it back Friday. There is also a few things you can do with the valve lash to help your performance a little i tightened mine up to .09 and .16 thats not the final setting though im gonna play with it a little try a few things east coast told me.
1 - 20 of 30 Posts
