Firing order 1,5,3,6,2,4 What was exhaust at?
Good question, very critical with interference motor valves/rockers are right, should always triple check valve/rockers are okay and be very careful on #6 cylinder see alot issues with it.
Double check trunnion in rockers not to damaged, perform adjustment then lasts step spin engine by hand before starting, recheck all good
For valve adjustment I set crank to TDC then make better mark on damper before remove rockers.
rotate crankshaft to align damper TDC mark to 12:00 o’clock position.
(a) If both number one cylinder rocker levers are loose, continue to next step.
(b) If both number one cylinder rocker levers are not loose, rotate crankshaft 360 degrees.
With the engine in this position, valve lash can be measured with feeler gauge at the following rocker arms:
INTAKE 1–2–4 / EXHAUST 1–3–5.
Tightening the lock nut to 24 Nm (18 ft. lbs.) and re-check the valve lash.
Using the crankshaft barring tool, rotate the crankshaft one revolution (360°) to align the
damper TDC mark to the 12 o’clock position. With the engine in this position, valve lash can be measured at the remaining rocker arms:
INTAKE3–5–6 / EXHAUST 2–4–6. Use the same method as above for determining whether adjustment is necessary,
and adjust those that are found to be outside of the limits
Cold engine below 70 F
INTAKE 0.254 mm (0.010 in.)
EXHAUST 0.508 mm (0.020 in.)
